bolo
- Mar 27, 2023
- Rhode Island
I started buying roll pattern dies from the turn of the century clear through the 1930s, maybe longer. I've been told many are hand cut. They run anywhere from 3" OD to 1"OD. Different presses are used to press the patterns into bracelets/ decor etc. I got the itch to start making some of my own dies (patterns) but I have questions. As expected hand engraving the detail into steel is challenging and I don't have the skillset for it. I have done some digging into using a pantograph - gorton or deckel - Assuming a 3d machine but not sure - I know the roll attachment for a gorton is rare - the deckels seem to be a bit more available. Is this direction a good one to pursure to engrave the dies I want to make ? Carving into a softer material to create a pattern and then have the pantograph engrave it onto the round die. Thickness of the die is anywhere from 2" to 1/4" depending on the pattern.Any insight - thanks.
