That has nothing to do with it, strictly coincidental.415 is twice 208.
Bought first ever machine that requires 415 volts input. I thought Europe was 380 or 400 volts...who is 415...UK ? AU ? Afganistan ?? The Vatican ???
Sure, but what does that have to do with 415 being (roughly) twice 208?"Coincidental"? Isn't 416 simply the line-to-line voltage in a system that provides 240 line-to-neutral in the same way that 208 is the line-to-line voltage in a 120/208 wye system?
That's not a coincidence, it's the square root of 3...
Just so you know, 415V 50Hz is roughly the same V/Hz ratio as 480V 60Hz. So you can use 480V supplies to your motorized equipment. The motors will run 20% faster because of the frequency difference, so they will technically put out more HP and you need to make sure that doesn't cause you any problems. But do NOT buy a transformer to step down to 415V and then feed it with 60Hz power, you will smoke your motors.
Pretty sure he means that if you use the transformer to lower the voltage the frequency will not lower so your voltage to frequency ratio will be off.Dear Tesla @Jraef
any chance you explain exactly why it might burn?
The situation is we use 415 with step down transformer instead of 480 so lower voltage, i understand that V/F control requires maintaining the ratio of 8 but still cannot connect the dots..
3 phase power in the UK is commonly referred to as 415V. Has been that way for as far back as I can remember.Bought first ever machine that requires 415 volts input. I thought Europe was 380 or 400 volts...who is 415...UK ? AU ? Afganistan ?? The Vatican ???
Leg to leg. Not phase to phase. Phases are between the legs.Looking at my single phase voltage in the house, just now, it's at 245V. Which would be 424V phase to phase.
PS:- this is a bit of a necro-thread...
Notice
